Hello all , can someone help me ... when I open an external file I need to select a dimension and keep its properties to continue the dimension .. there is the possibility of acquiring the properties of a dimension to then keep them and continue my dimensioning like this .
Thank you
Hello
You can check on the Ctrl+1 property bar which dimension style is used in the drawing.
Then use the DIMSTYLE command to set this dimension style as the default and continue dimensioning.
You can do it like this:
1. Load the script via APPLOAD and add it to the startup list
2. In the CUI editor, add any command where you want
3. Select the icon and change the descriptions and, above all, the executed command to the one that loads the script
4. You can change the icon to your own (16x16 or 32x32 pixels)
