Próbowałem sprawdzić ObjectZRX do Plusa i niestety poległem. Czy ktoś próbował kompilować pod ZwCAD+ aplikację zrx? Ja dostaję takie komunikaty :
log VS2010
1>------ Build started: Project: DrawLine, Configuration: Release Win32 ------
1>Build started 2012-09-11 11:40:35.
1>PrepareForBuild:
1> Creating directory "D:\_projekty\ObjectZRX\2012_plus\Samples\Release\".
1>InitializeBuildStatus:
1> Creating "Release\DrawLine.unsuccessfulbuild" because "AlwaysCreate" was specified.
1>ClCompile:
1> stdafx.cpp
1> DrawLine.cpp
1>Link:
1> Creating library D:\_projekty\ObjectZRX\2012_plus\Samples\Release\DrawLine.lib and object D:\_projekty\ObjectZRX\2012_plus\Samples\Release\DrawLine.exp
1> Generating code
1> Finished generating code
1>ZwRx.lib(zwrxlib.obj) : warning LNK4099: PDB 'vc100.pdb' was not found with 'ZwRx.lib(zwrxlib.obj)' or at 'D:\_projekty\ObjectZRX\2012_plus\Samples\Release\vc100.pdb'; linking object as if no debug info
1> DrawLine.vcxproj -> D:\_projekty\ObjectZRX\2012_plus\Samples\Release\DrawLine.zrx
1>FinalizeBuildStatus:
1> Deleting file "Release\DrawLine.unsuccessfulbuild".
1> Touching "Release\DrawLine.lastbuildstate".
1>
1>Build succeeded.
1>
1>Time Elapsed 00:00:09.82
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
Command: _appload
DrawLine.zrx is incompatible with this version of ZWCAD.
ZwRxDynamicLinker failed to load
'D:\_projekty\ObjectZRX\2012_plus\Samples\Release\DrawLine.zrx'
C:\Program Files\ZWCAD_Plus_2012EN\ZWCAD.exe
D:\_projekty\ObjectZRX\2012_plus\Samples\Release\DrawLine.zrx loaded failed!
