Problem whit the "Enhanced Ordinate Dimension" [Solved]
Hello everybody ,
I have a problem using ZWCad MFG 2024 , I have attached a short video to understand better. When I use the "Enhanced Ordinate Dimension" function, it happens that when I select the "Update" option, it doesn't give me the possibility to select the objects to modify but I attach the dimension automatically to the origin ...
Anyone know what it could be?
Thank you
I cannot confirm the reported issue. I do it on the same version (probably), in two ways and it comes out right every time.
Maybe it's worth checking in another drawing? Maybe there are some programs loaded that are interfering with it?
  • dmatusz3 zmienił(a) tytuł na Problem whit the "Enhanced Ordinate Dimension" [Solved]
