convertpoly
alf
nie działa, ale dorzuciłam do tego:
(defun c:2D2 (/ s i)
  (if (setq s (ssget '((0 . "POLYLINE") (-4 . "<not") (-4 . "&") (70 . 120) (-4 . "not>"))))
    (repeat (setq i (sslength s))
      (OldStyle2LwPolyline (ssname s (setq i (1- i))))
  (princ)
jeszcze to, to ze strony https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-routine-to-convert-2d-polyline-to-polyline/td-p/7124499:  i teraz działa. Nie wnikam jak ;-), dzięki!
;; OldStyle2LwPolyline (2008/03/31)
;; Replace a 2d polyline with a light weight polyline
;; Argument : 2d polyline (ename)
;; Return : light weight polyline (ename)
(defun OldStyle2LwPolyline (pl / plst xdata vtx vlst elst)
  (setq	plst  (entget pl '("*"))
	xdata (assoc -3 plst)
	vtx   (entnext pl)
  (while (= (cdr (assoc 0 (setq vlst (entget vtx)))) "VERTEX")
    (if	(zerop (logand (cdr (assoc 70 vlst)) 16))
      (setq elst (cons (vl-remove-if-not
			 (function
			   (lambda (x)
			     (member (car x) '(10 40 41 42))
			 vlst
		       elst
    (setq vtx (entnext vtx))
  (if (setq new
	     (entmakex
	       (append
		 (list
		   '(0 . "LWPOLYLINE")
		   '(100 . "AcDbEntity")
		   (assoc 410 plst)
		   (assoc 8 plst)
		   (cond
		     ((assoc 39 plst))
		     (T '(39 . 0))
		   '(100 . "AcDbPolyline")
		   (cons 90 (length elst))
		   (cons 70 (logand 129 (cdr (assoc 70 plst))))
		   (cons 38 (last (caar elst)))
		   (assoc 210 plst)
		 (apply 'append (reverse elst))
		 (if xdata
		   (list xdata)
    (entdel pl)
  new
