W LISP za przykład może posłużyć :
(setq defnition(entmake (list (cons 0 "BLOCK") (cons 100 "AcDbEntity")(cons 100 "AcDbBlockBegin")(cons 67 0)(cons 8 "0")(cons 70 0)(cons 10 (list 0.0 0.0 0.0))(cons 2 "*Z")(cons 1 ""))))
(setq LiniaDef(entmake (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine")(cons 10 (list 0 0 0))(cons 11 (list 100 120 0)))))
(setq BezNazwa(entmake '((0 . "ENDBLK"))))
(setq Insertion(entmake(setq naglowek (list '(0 . "INSERT") '(100 . "AcDbEntity")'(100 . "AcDbBlockReference") (cons 2  BezNazwa) (cons 10 (getpoint)) (cons 50 0) '(66 . 1) ) )))
(entmake (quote((0 ."SEQEND"))))
Działa łądnie ale tylko w Au.. (programie konkurencyjnym). W ZWCadzie wyskakuje błąd:
error: *Error*
(VLA-ADD (VLA-GET-BLOCKS DOC) (VLAX-3D-POINT POINT) NAME)
(SETQ NAME# (VLA-ADD (VLA-GET-BLOCKS DOC) (VLAX-3D-POINT POINT) NAME))
((LAMBDA ( ) (VLA-COPYOBJECTS DOC )) (SETQ NAME# (VLA-ADD (VLA-GET-BLOCKS DOC) (VLAX-3D-POINT POINT) NAME)) (VLAX-SAFEARRAY-FILL (VLAX-MAKE-SAFEARRAY VLAX-VBOBJECT (CONS 0 (1- (LENGTH SS#)))) SS#))
(KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC))
(SETQ BN# (KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC)))
(PROGN (SETQ ZD (TRANS (QUOTE (0 0 1)) 1 0 T)) (SETQ BN# (KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC))) (FOREACH S# (VLA-DELETE )) (KR:BLK_INSERTBLOCKVLA (TRANS BP 1 0) (SETQ BN (KR:BLK_GETBLOCKNAME BN#)) 1 1 1 0) (PRINC (STRCAT "\n>> Anonymous block " BN " created. <<")))
(IF (SETQ SS (SSGET)) (PROGN (SETQ ZD (TRANS (QUOTE (0 0 1)) 1 0 T)) (SETQ BN# (KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC))) (FOREACH S# (VLA-DELETE )) (KR:BLK_INSERTBLOCKVLA (TRANS BP 1 0) (SETQ BN (KR:BLK_GETBLOCKNAME BN#)) 1 1 1 0) (PRINC (STRCAT "\n>> Anonymous block " BN " created. <<"))) (PRINC "\n** Nothing selected **"))
(PROGN (PRINC "\nSelect object to convert to block: ") (IF (SETQ SS (SSGET)) (PROGN (SETQ ZD (TRANS (QUOTE (0 0 1)) 1 0 T)) (SETQ BN# (KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC))) (FOREACH S# (VLA-DELETE )) (KR:BLK_INSERTBLOCKVLA (TRANS BP 1 0) (SETQ BN (KR:BLK_GETBLOCKNAME BN#)) 1 1 1 0) (PRINC (STRCAT "\n>> Anonymous block " BN " created. <<"))) (PRINC "\n** Nothing selected **")))
(IF (SETQ BP (GETPOINT "\nSelect insertion point for block: ")) (PROGN (PRINC "\nSelect object to convert to block: ") (IF (SETQ SS (SSGET)) (PROGN (SETQ ZD (TRANS (QUOTE (0 0 1)) 1 0 T)) (SETQ BN# (KR:BLK_MAKEBLOCKVLA (TRANS BP 1 0) "*U" (SETQ SS# (KR:SSX_SS->VLA SS)) (KR:ACX_ADOC))) (FOREACH S# (VLA-DELETE )) (KR:BLK_INSERTBLOCKVLA (TRANS BP 1 0) (SETQ BN (KR:BLK_GETBLOCKNAME BN#)) 1 1 1 0) (PRINC (STRCAT "\n>> Anonymous block " BN " created. <<"))) (PRINC "\n** Nothing selected **"))) (PRINC "\n** Invalid point **"))
(C:MAB)
