s1016 Opublikowano 4 Grudnia 2020 Zgłoś Opublikowano 4 Grudnia 2020 Serdecznie proszę o wsparcie, znalazłem lispa wstawiającego blok w zadanej odległości na krzywej. Wszystko działa na zwcadzie bez zainstalowanego ZWTraffic. W zwcadzie z tą nakładka dostaję błąd po podaniu odległości : Distance to Block Insertion: 8.16 ZWTrafficUpdate-evaluate:*error*: niepoprawny typ argumentu: consp: nil Cytuj ;| PUT.LSP ver. 2.0 (c) 2005 Tee Square Graphics Improved version of PUT.LSP originally published in 1998. This version avoids the use of the native MEASURE command, using instead the curve functions of Visual LISP (VLISP). PUT places a single block insertion a user-specified distance from the selected end of a non-closed AutoCAD object (i.e., ARC, LINE, POLYLINE, LWPOLYLINE, SPLINE). |; (defun C:PUT (/ os ce bm blk ent obj ppt dst ept ref len ipt par slp ang) (command "_.undo" "_be") (setq os (getvar "osmode") ce (getvar "cmdecho") bm (getvar "blipmode") blk "" );;setq (if (not bk)(setq bk "")) (setvar "osmode" 0) (setvar "cmdecho" 0) (setvar "blipmode" 0) (while (not (setq ent (entsel "\nSelect object near reference end: ")))) (while (and (not (tblsearch "block" blk)) (not (findfile (strcat blk ".dwg"))) );;and (setq blk (getstring (strcat "\nBlock to use <" bk ">: "))) (if (> blk "")(setq bk blk)(setq blk bk)) );;while (setq obj (car ent) ppt (osnap (cadr ent) "nea") dst (getdist "\nDistance to Block Insertion: ") ept (vlax-curve-getEndPoint obj) ref (vlax-curve-getDistAtPoint obj ppt) len (vlax-curve-getDistAtPoint obj ept) );;setq (if (> ref (/ len 2.0)) (setq dst (- len dst)) );;setq (setq ipt (vlax-curve-getPointAtDist obj dst) par (vlax-curve-getParamAtPoint obj ipt) slp (vlax-curve-getFirstDeriv obj par) ang (atan (/ (cadr slp)(car slp))) );;setq (entmake (list '(0 . "INSERT") (cons 2 blk) (cons 10 ipt) (cons 50 ang) );;list );;entmake (setvar "osmode" os) (setvar "cmdecho" ce) (setvar "blipmode" bm) (command "_.undo" "_e") (princ) ) (alert (strcat "PUT.LSP ver. 2.0 (c) 2005 Tee Square Graphics" "\n\n Type PUT to begin." ) )
s1016 Opublikowano 5 Grudnia 2020 Autor Zgłoś Opublikowano 5 Grudnia 2020 Przyznaję, pierwsza diagnoza była błędna, zmylił mnie test na zw2019 na którym nie mam ZWTraffic. Tam lisp chodzi dobrze. Na zw2020 po dłuższym poszukiwaniu okazało się, że wystarczy zmienić: ppt (osnap (cadr ent) "nea") na ppt (osnap (cadr ent) "_nea") i lisp działa, przepraszam autorów zwTraffic o niesłuszne oskarżenia kruszynski 1
