Poniższy kod (działający w ACAD) powinien jako wyjście dać wielostronicowy plik PDF umieszczony w katalogu rysunku:
using (Transaction tr = db.TransactionManager.StartTransaction())
            DsdEntryCollection collection = new DsdEntryCollection();
            foreach (ObjectId layoutId in layoutList)
                Layout layout = tr.GetObject(layoutId, OpenMode.ForRead) as Layout;
                if (!layout.LayoutName.Contains("Model") && layout.LayoutName.Contains(layoutName))
                    DsdEntry entry = new DsdEntry
                        DwgName = doc.Name,
                        Layout = layout.LayoutName,
                        Title = layout.LayoutName,
                        Nps = layout.PlotSettingsName,
                        NpsSourceDwg = doc.Name
                    collection.Add(entry);
            string pdfFile = (path == "" ? dwgPath : path) + name + ".pdf";
            DsdData dsdData = new DsdData
                SheetType = SheetType.MultiPdf,
                ProjectPath = path == "" ? dwgPath : path,
                DestinationName = (path == "" ? dwgPath : path) + name + ".DWG",
                IncludeLayerInfo = true,
                PromptForDwfName = false
            string dsdFile = dwgPath + name + ".dsd";
            if (System.IO.File.Exists(dsdFile)) System.IO.File.Delete(dsdFile);
            dsdData.SetDsdEntryCollection(collection);
            string str, newStr;
            string tmpFile = Path.Combine(dwgPath, "temp.dsd");
            dsdData.WriteDsd(tmpFile);
            using (StreamReader reader = new StreamReader(tmpFile))
            using (StreamWriter writer = new StreamWriter(dsdFile))
                while (!reader.EndOfStream)
                    str = reader.ReadLine();
                    if (str.Contains("Has3DDWF"))
                        newStr = "Has3DDWF=0";
                    else if (str.Contains("OriginalSheetPath"))
                        newStr = "OriginalSheetPath=" + dsdData.DestinationName;
                    else if (str.Contains("OUT"))
                        newStr = "OUT=" + dwgPath;
                    else if (str.Contains("IncludeLayer"))
                        newStr = "IncludeLayer=TRUE";
                    else if (str.Contains("PromptForDwfName"))
                        newStr = "PromptForDwfName=FALSE";
                    else if (str.Contains("LogFilePath"))
                        newStr = "LogFilePath=" + Path.Combine(dwgPath, "print.log");
                    else
                        newStr = str;
                    writer.WriteLine(newStr);
            File.Delete(tmpFile);
            dsdData.ReadDsd(dsdFile);
            if (System.IO.File.Exists(pdfFile))
                System.IO.File.Delete(pdfFile);
            using (PlotConfig pc = PlotConfigManager.SetCurrentConfig("DWG to PDF.pc5"))
                publisher.PublishExecute(dsdData, pc);
			tr.Commit();
Przygotowany plik .dsd jest poprawny.
Wykonanie metody
nie powoduje nic, ani błędu, ani poprawnego działania, czyli wyświetlenia okna z postępem drukowania.
Nie pracowałem wcześniej z DSD, więc nie umiem powiedzieć nic pewnego, ale chciałem dopytać w ZWSOFT o szczegóły.
Przesłany kod, to tylko fragment większej całości. Zakładam, że mógłbym obudować ten fragment całością, którą dałoby się skompilować, i przetestować, ale mogłoby się okazać, że coś zrobiliśmy inaczej, co da różne wyniki. W związku z tym proszę o przesłanie szerszego fragmentu, pozwoli na wierne odtworzenie sytuacji.
